Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 41
    ^^^ i actually bought this up on PA v1 years ago, I'd go so far as to say that it's simply that they haven't been submitted for testing for approval.
    From what i've read the aluminium crimped Goodridge ones fail the ADR wip test as the aluminium cuts into the braid. Some Goodridge lines may be ADR certified however not all are. You need to check if buying them.
    But it's good to see some guys here do have the ADR certified lines.
    2,980
    it's not worth risking yours or someones elses life to save $50 when it comes to brakes and the braking system
    Been running the goodridge lines on the 4g for a number of years now - they're holding up fine.
    Yes mine too. The point of all this is the legalities. Although I'm sure there are many other non-legal things we do too.....
    My Goodridge lines are DOT approved. From what I read DOT approval requires subjecting to the same 35hr pressurised whip test as the ADR whip test. Silly standards.
    VTiR ATTS
    572
    Was going to buy some till I realised that my car came from Honda with them. Still working fine after maybe 7+ years. Maybe I should replace them? Less than 50,000km's, but still. Car was serviced just last week, but as per the OP, you can't really inspect them.
    Pretty sure there was a trader on OzHonda who sells ADR approved goodridge lines.
    Feb 2010
    11
    Share a plug who did your adr lines bob? and how much $$$?
    Solve world petrol crisis, tune lean!
    Mine are not ADR so far as I can tell. They are Goodridge G-Stop, DOT approved as purchased from the states. This is my concern. I'm contemplating if I should be re-installing the stock lines or getting a set of ADR braided lines made.
    VTiR ATTS
    572
    JDM Yard has them for $185 shipped Australia wide. Have to order them in for our cars though, so maybe the price would be higher? Be exactly the same lines I would imagine, just with ADR tags. Then again they are supposed to be from the UK, so I guess they could be different.
    http://www.ozhonda.com/forum/showthr...-%29-*JDMyard*
    Senior Member Gaz's Avatar
    674
    I would be intersted in a set of these, but would need them installed too
    if ya want to be different go buy a citroen or some shit.
    Those are the same lines as mine. Note that the product does not refer to the ADR approval.
    The seller states FMVSS 106 which is the DOT standard. This DOES NOT mean that they are ADR approved.
    I'd love to see the ADR certification proof on these.
    VTiR ATTS
    572
    http://www.perthbrakeparts.com.au/ss-braided-hoses.asp <- sells ADR approved and suggests that maybe the regular Goodridge aren't? I get the feeling that all the claims that they are ADR approved just mean that they would pass (since they have passed similar tests elsewhere), but they aren't actually approved and therefore not street legal.
    At any rate my car came with Goodridge lines installed by Honda Australia. Hard to make out the yellow label without taking the wheel off, but it also appears to say racing.
    Mar 2010
    217
    If you can organise a set of braided brake lines for under $200 a set, and will help support local aussie industry, you can count me 100% in. I am replacing my discs and pads, so might as well. I was shopping around for braided lines already.
    I am planning to replace my brakes in 2 months so keep us updated?
    Quoting someone else from Perth-WRX today.
    Perth brake parts made my braided clutch line for $110
    They also quoted me $130 per brake line, you must provide a sample
    So at $520 and you fit yourself. No thanks. It's got me stuffed why the ADR ones cost so much more than the DOT approved ones. It's not like the materials cost more....
    Regular Member forbeszy's Avatar
    Mar 2010
    165
    http://cgi.ebay.com.au/HEL-braided-b...item3ca9abfede
    These HEL lines on ebay say they are ADR approved, decent price also.
    I got my clutch line done in braided SS, took the stock one off took it to brake/clutch line shop & 10 minutes later at $80 was all done and legal... I forgot to ask how much for the brake lines tho
    674
    Pretty good deal, i would get em but i wouldnt know how to fit them myself
  1. [3rd Gen] Stainless Steel Braided Brake Line Install
    By racinghonda in forum Write-Ups
    Last Post: 23rd October 2011, 07:58 PM
  2. Q & A - Exhaust
    By shakes in forum Fifth Generation
    Last Post: 5th September 2009, 11:29 PM
  3. Write Up: Changing Brake Pads
    By racinghonda in forum General Prelude Discussion
    Last Post: 26th November 2006, 08:55 AM
