Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
    79
    setting up footwell neons =\
    hey .. just wondering if theres any tutorials on setting up footwell neons in cars .. or could somone explain how its done .. never done this mod before and trying it in friends car..
    also what tools + materials u need ??..=\ .. thought just ned the neons and wire n thats it but heard need more ..
    Regular Member Red89Prelude's Avatar
    2.0 Si
    Dec 2006
    202
    i dont no if this is what you ment but try this
    http://www.preludeaustralia.com/foru...=view&tutid=30
    Silver Member -dB-'s Avatar
    Feb 2005
    1,206
    Quote Originally Posted by Red89Prelude View Post
    Beat me to it lol
    Gold Member Menthu Rae's Avatar
    5th Generation
    VTi-L
    Mar 2005
    2,389
    Required:
    ? x Neons
    ? x Inverters (same amount... should come with the Neon, provides the correct voltage to it)
    ? x Metres of wire (~16 gauge should be fine)
    ? x Metres of electrical tape
    1 x Multimeter to check voltages/currents/etc [Not 100% necessary]
    1 x Soldering Iron
    1 x Roll of Solder
    1 x Box of connectors/Crimping kit
    1 x Crimper
    Basically you have a few options...
    * You can wire them up directly to your battery, with an inline fuse between them, and a switch... so you can turn them on/off at will...
    * You can wire them up to behind your cigarette lighter socket, if you don't use it, in the same way as above...
    * You can wire them up, using a relay, to your accessories, so they turn on/off with your headlights/parkers...
    Basically all you do, is connect the +ive wire of the neon to the +ive wire of your battery/cig lighter/accessories... and the -ve wire of the neon to some grounding point in your car (bolt located on the chassis, a wire that is grounded somewhere, etc).
    If you are unsure of what you're doing, I suggest you get someone else to do it... otherwise read through these guides for a VW and take note of what he actually did... be very very careful though, as if your car has airbags - playing around with the electronics/circuits inside could set them off if you do something wrong.
    http://forums.vwvortex.com/zerothread?id=961773
    http://forums.vwvortex.com/zerothread?id=1578754
    2001 Honda Prelude VTi-L [NH-623M]
    BB6 Squad Member #2 [BBH.22A]
    79
    thx.. .. and also for quick response.. ill give it a go but those fuses one looks damn complicated.. most likly hook the neons to the ciggy port ..thx agen ppl .
    BTW dont u need a inline-fuse ? .. the fuse that goes before the switch.. iunnos correct me if im wrong
    could u use the ciggarette port for the ciggarette thing still even thou its used for neons? ..
    A lot of PPL have done this and there is great writeups on it (like db's) so I don't know if your interested but I used LED arrays instead of neons and built a controller for them that senses the current to the interior light. That way they would come on only when the doors were opened.
    In the controller I built in a 2 sec delay so that when the doors were closed they stay on for 2 sec and then fade out to black.
    I'm sure it has been done but I wanted to do it myself. (theres nothing like DIY ) and also it is automatic which I like cause I'm lazy.
    Anyway here is a small vid I took of the result.
    http://s176.photobucket.com/albums/w...t=CIMG2200.flv
    Cheers.
    4th Generation
    391
    Quote Originally Posted by Scotty View Post
    Cheers.
    thats more of a picture with a timer lol. unless something buggered up.
    hey outta curiousity - where did everyone bolt the neons too??? i screwed them into the plastic which is sturdy as shit but u can sometimes see them if u sit low enough which is annoying. i want them to be hidden.
    Quote Originally Posted by maxwell_47 View Post
    I was wondering if it would work....
    It's the first time I tried to get a video to work from photo bucket
    I'll try something else
    Hmmm...dont know whats wrong, just tried it on another computer and it works fine.
    Sorry if you couldn't see the vid, anyway here is a pic...The passenger side LED array is screwed in right next to the screws that hold the glove compartment in place and the leds are faced towards the firewall (the led's are pretty bright and the light fills the foot wells)
    The drivers side was a bit harder, I ended up drilling two holes in the plastic that covers the "underside" of the steering column and cable tying it in.
    Looks ok and you can't see the led arrays even if you look in to the car from a distance. Just a blue glow.
    Gold Member andy's Avatar
    Mar 2006
    2,974
    man it aint that hard lol.
    i found the best way was to cabletie the neons to something as bolt locations are shite in 4th gens
    "If sparks don't fly your rides' too high"
    Silver Member
    1,743
    every time i have seen neons in the foot well im always amazed at how much dirt it shows up in the carpet.
    Mugen parts make me wet...
    2nd Generation
    564
    i just hooked mine into the boot light...is that a not good thing to do??
    BLOOOOOOOD!!!! Manabir's Avatar
    AUII XR8 220
    Jan 2005
    3,667
    then you only get them when the bootlights on.
    depends what you want them for.
    if you want them on when the doors open the hook them up to the certacy light in the door.
    if you want them on when the lights are on hook them up to the tail light fuse.
    if you want them on when you want them on hook them up direct to the batter with a switch and a relay.
    its up to you...but i cant see the point of the bootlight.
    i got mine hooked up to the tail light fuse so as soon as the tail lights come on the neons come on.
    the ones in the foot well, the ones on either side of the shifter and the one in the guage cluster.
    the ones on my sub box are hooked up to the boot light though.
    cause you can only see them when the boots open.
    A completed modified car is an ever changing goal that can never truly be achieved.
    CLICK to see my progress towards this impossible end.
    Mugenator skinnyboy's Avatar
    Hybrid S and VTiR
    Apr 2005
    3,036
    make sure you always wear white socks, to accentuate your neon-ness!
  1. Neons Instead Of Trunk Light
    By o0pz83 in forum Third Generation
    Last Post: 2nd June 2008, 08:00 PM
  2. underbody neons power source?
    By bennyboi in forum I.C.E / Electronics / Security
    Last Post: 3rd February 2007, 08:29 PM
  3. Footwell Neons
    By mattsama in forum I.C.E / Electronics / Security
    Last Post: 10th September 2006, 10:34 PM
  4. door lights + neons
    By john-e boi in forum Third Generation
    Last Post: 12th June 2006, 01:19 PM
  5. Tutorial - Amplifier Gain & Crossover Adjustment
    By typevu in forum I.C.E / Electronics / Security
    Last Post: 29th May 2006, 04:31 PM
