Page 9 of 9 FirstFirst ... 789
Results 121 to 132 of 132
  1. #121
    Sorry bob! I meant 205/40/17!!! my bad. On tire-rack now.
    Yokohama S drive? Or Kumho Ecsta ASX/AST? All are 215/40 with the required load rating but at least they are still legal.
  2. #122
    Quote Originally Posted by SnowWhiteLude View Post
    I will have a look at those for myself. And does anyone else know of any good tyres that are either 215/40/17 or 205/40/18 with a load rating of 85? I wanted the Federal 595's but they are too low.
    Looking for something around the $600 mark for 4.
    the 595's i've found are apparently 87v, they must make different types or something :/
  3. #123
    4X-215-40-17-GOODYEAR-EAGLE-F1
    http://www.ebay.com.au/itm/4X-215-40...#ht_2163wt_962
    4X-215-40-17-KUMHO-KU27
    http://www.ebay.com.au/itm/4-X-215-4...#ht_2580wt_962
    all within the price range.
  4. #124
    If u r in Melb.
  5. #125
    KU27 or KU36? Would probably like the better of the two - any feedback? Also any feedback on the Goodyear. I have seen both of those but havent heard much on either.
    Quote Originally Posted by Brendan Trickett View Post
    215/45/17 are 87... But slightly bigger than what I am after (215/40/17).
  6. #126
    Sep 2010
    976
    I'm using Goodyear F1's at the moment and it's VERY difficult affair to break traction.
    I've had them for about 15,000K's the previous owner must have done around 5-10,000 I think because my fronts are worn out, but my rears are on about 40-50%.
    Considering the inner wear that's now made them illegal to drive on the road, the 68-32 F/R weighting the the Prelude and my driving style I would assume with a rotation you would see 40,000-45,000 on them (I didn't rotate).
  7. #127
    May 2010
    366
    I have a question for people.. If i wanted to fit a 8 - 8.5" Rim on the rear and hopefully a 7.5 - 8" inch on the front.. would a 215/40/17 tyre be suitable and also the rolling of guards would clear this setup? Want to run a offset of say +25 or +35.. have seen the wheels i like with a +35 17" rim on a 5th gen in the U.S.. thoughts?
  8. #128
    Sep 2010
    976
    What does everything think of this?
    Obviously the size is huge, I think those were a god damn 20, but you get the idea.
  9. #129
    Regular Member Gregsir's Avatar
    225
    Looking to get 2 front tyres for the lude and wondering has anyone got any new input on whats proven good out there?
    Was looking at Goodyear f1's or the Bridgestone re0's and looking to spend $200 on each,the Advans they are going on to are quite a big 17in rim to cover.
    The rears have 225/45r17 90W and whilst good tyres they look very bulky overall on the wheel,they'll get done after the festive season.
  10. #130
    2nd Gen
    Mar 2016
    2
    hey guys, just wondering if I would get away with a 235/40r18 on the front of my 4th gen or would I get rub when I'm full lock?
  11. #131
    Did you read page 1 at all?
    It all depends on if/how much you are lowered and the offset of the wheels. A 235/40R18 is a crazy big tyre on any width wheel though, it's nearly 40mm larger in diameter than the stock tyres so it'll lift the car by 1/2 that and throw your speedo out about 6%. If for instance you are looking at an 18x8 +32 (a fairly common size) then you are also losing nearly 40mm of guard clearance compared to stock. I really doubt it would work.
    18's look like junk on 4th gens too. If you are dead set on them then you would be much better off with a 225/35R18, with an appropriate width/offset wheel this should clear.
  12. #132
    2nd Gen
    Mar 2016
    2
    Honestly I find page 1 quite unhelpful but thanks for that mate
  1. Tyre Pressures
    By eein in forum Fifth Generation
    Last Post: 24th December 2004, 12:44 AM
  2. TSB - 00-088 - Brake Disc Refinishing Guidelines (All)
    By djroketboy in forum Technical Service Bulletins
    Last Post: 12th November 2004, 11:07 AM
