Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 132
    Regular Member fintelboss's Avatar
    Oct 2007
    220
    sorry bob, i think we keep having the same misunderstanding...
    wider tyre means the contact patch is wider, but also shorter. the same area of rubber must be on the road. simple F = P*A
    it seems a lot of people think that by fitting fat tyres they will have more grip because there is more tyre on the ground. this simply cannot the reason, because we know the area of the contact patch is exactly the same size.
    i dont know much about improving grip, but isnt the only cause a change in the way the tyre deforms when its spinning round and round, or the rubber stickyness and tyre temp?
    add to this that when people get fatter tyres, they normaly start running higher pressures, like 35+ psi, so they now have a smaller contact patch then the standard, 30 to 34 psi in a skinnyer tyre.
    i read the carbible articles long ago, and so far as i can see everything i have said is found in it.
    can you point out anything ive got wrong?
    thanks!
    ---Life without geometry is pointless.---
    Quote Originally Posted by fintelboss View Post
    I don't know much about improving grip, but isn't the only cause a change in the way the tyre deforms when its spinning round and round, or the rubber stickiness and tyre temp?
    add to this that when people get fatter tyres, they normally start running higher pressures, like 35+ psi, so they now have a smaller contact patch then the standard, 30 to 34 psi in a skinnier tyre.
    can you point out anything I've got wrong?
    thanks!
    Sorry bloke I missed this one.
    I think you are on the right track. Wider does not necessarily give better grip.
    Regular Member jmsin1's Avatar
    5th Generation
    195
    hai guise.
    I looking at some 17* 7 ROH wheels which apparently are +32 Offset. I have read the facts etc but just want to confirm that they are not suitable for a 5th gen??
    Is this mainly due to too much rubbing??
    a s s e m b l e . y o u r . c r e w
    Junior Member karlos's Avatar
    Nov 2007
    97
    guys urgent help, will these rims pass the standard load ratings for 4th gen?
    http://cgi.ebay.com.au/Lenso-18X8-Al...QQcmdZViewItem
    i'd say you should be requesting what the load rating of the tyre is too if you are concerned....
    Nov 2007
    97
    what happens if its less than the recommended rating that it says?
    not good... basically it cannot support the weight of the vehicle adequately. mate sure the load rating of both rim and tyre is adequate. i dont know too much stuff about this kinda thing tho so i guess you'd be better off waiting for a more knowledgeable reply
    Beige Leather
    2,083
    Hmmm, from memory the load rating is about 92 for a 5th gen (someone correct me). It'd be a little less for a 4th gen
    The load rating for 215/35R18 in this tyre is only 84 with extra load rating... quiet low, I wouldnt recommend it..
    Thats a pretty bad tyre size choice to begin with, he's really stretching a small width tyre out for an 8" rim.
    I'd be vary wary about buying an 8" rim for a lude to begin with.. even with a high offset around +45 may still result in scrubbing.. He doesnt say what the offset is with these rims either
    http://www.falken.com.au/tyres/passenger-FK452.html
    PA Resident brash's Avatar
    4,177
    I've never heard of anybody having an 8inch wide rim on a Prelude without trouble. That's not saying it doesn't happen, just that in my years of spending time on every lude forum known to man, I've not heard of it.
    4,177
    Just thought I'd add this into the thread, after a little research. I may add to this post again later.
    8" Wide Wheels w/ 5th gen
    Some have had success with offset of +45
    Tyres
    215/35/19 - Large contact patch, recommended 19" tyre
    (I've been searching all night, and not found anybody using any other size on a 19 inch rim with any level of success)
    Senior Member Luder88's Avatar
    Jun 2007
    983
    On the 1st page it doesn't mention anything about 205/45/R16 tyres.
    Would this be suitable on stock rims but the lude is lowered say... 1.5"?
    4,177
    Stock size is 205/50, so a /45 is slightly lower profile, your tyres will have a slightly smaller circumferance. Yes it will suit, but the lower circumference will push your speedo out, slightly.
    Oct 2007
    220
    you will get less speeding tickets, and shave a few 10ths of a second off your 0-100 time
    Jun 2007
    983
    Yeap sweet as brash. I think I understand now. So what you're trying to say is that if I'm traveling @ a constant speed of 60Km/hr the speedo will be showing 60km/hr but am I actually goin quicker or slower by ~1-2km?
    Cheers =)
    Oct 2007
    220
    3.6km/h slower
  1. Tyre Pressures
    By eein in forum Fifth Generation
    Last Post: 24th December 2004, 01:44 AM
  2. TSB - 00-088 - Brake Disc Refinishing Guidelines (All)
    By djroketboy in forum Technical Service Bulletins
    Last Post: 12th November 2004, 12:07 PM
