Results 1 to 15 of 16
    Senior Member CUL8R's Avatar
    Jan 2005
    870
    Official 5th gen Dyno Sheets - no comments, posts without DYNo will be deleted
    Quote Originally Posted by CUL8R,Feb 9 2006, 10:07 PM
    I thought it would be a good idea for people to post their dyno sheets so fellow 5th genners know what mods are needed to reach XXX KW.
    Please post up a copy of your dyno sheet and mod list at the time.Dont hesitate if you're stock it would be good to track your progress or just interesting to see differences in stock ludes.
    Might be worth a sticky if it gets going!
    ill get the ball rolling
    MODS:
    *AEM V2 intake
    *Custom high flow cat --> 18"hotdog -->split at axle-->two mufflers (one on each side) exhaust. ugly angles for power!
    *VAFC2 tuned by Dr Drift
    KMS: 109000
    DYNO is brand new so pretty much spot on with a safe tune.
    [snapback]234021[/snapback]
    Quote Originally Posted by LEWD,Feb 10 2006, 12:25 AM
    I dont have a dyno sheet (long gone by now) but just for info
    S spec head (port polished, cams, larger throttle body etc etc)
    AEM CAI
    S spec pistons
    S spec headers and exhuast through to cat
    hi flow cat
    Apexi N1 exhaust with one small resonator
    Level 10 PTS kit inc freshly built tranny
    Apexi VAFC
    Properly tuned
    As close to 100 octane fuel in 2002 (ie optimax with octane booster)
    engine block 120,000km, head about 40,000km
    184hp@wheels +/- 10%
    can't remember torque, but it was pretty meaty...
    [snapback]234070[/snapback]
    Quote Originally Posted by DMT,Feb 10 2006, 03:00 PM
    114.7 kW @ 6,621 rpm (at the wheels)
    174.7 Nm @ 5,052 rpm (at the wheels)
    My runs were performed in 4th gear, only mods were:
    * Daiken Heavy Duty Clutch
    * Simota Pod Air Filter (100mm Neck)
    * Xplosion Twin Cannon Rear Muffler
    Pro-Tek Automotive
    Dynamic Test Systems
    Precision Dynamometers
    Here is a short video of the run taken and hosted by racinghonda (hope thats cool Rich?)
    Dyno Video
    [snapback]234208[/snapback]
    DMTs read about 10% high
    Quote Originally Posted by 5thGenGem,Feb 10 2006, 05:49 PM
    ok heres mine after tuning my VAFC2
    I had an xforce catback and type-s intake chamber as my baseline run. ~105KW
    My peak power increased about 5hp (woooot :hay: ) but i really dont care about that. i've always been wanted more mid-range punch and the plot tells the rest of the story I've got another pic with the torque curve so i'll post it up another time.
    Its interesting that the two runs look so different, yet the peaks are roughly the same. What are peoples diagnosis of this?
    [snapback]234256[/snapback]
    Quote Originally Posted by interludic2000,Apr 15 2006, 09:32 AM
    Some places do dynos in 3rd gear. So torque would read a lot higher than 4th gear.
    Here is mine before/after VAFC2 tuning. 14kw gain. Dyno'd 32 degree day, Adelaide around noon. The figures should be very accurate if not low. I had my car dyno'd on a DynoDynamics one at a place 3 weeks before that which had 107kw(colder day 9 in the morning) before VAFC2 tune.
    H/I/E
    Dunno what header I have.
    K&N Pod filter.
    2.5" exhaust, dunno brand came with car when i bought it.
    Small Mugen logo on side skirts(adds about 20kw).
    [snapback]255259[/snapback]
    Quote Originally Posted by grnLude,Apr 20 2006, 09:16 AM
    Here's mine -
    It was done on a -
    Dyno Dynamics - Porsch GT dyno (Temp was about 23 deg)
    Mods -
    - Hondata IM Gasket
    - CAI
    - Bored TB
    - Custom 2.25" Straight Through exhaust with OBX High flow cat/Test Pipe
    I was told that this dyno apprently reads lower than the other Dyno Dynamic dyno's. So....
    But their's a lot more push after the tune and the car revs so much easier now.
    This was my stock dyno-
    Big thanks goes out to - FITZGERALD RACING SERVICES for lending the dyno and ANDY (aka pornstar) for doing the tunning.
    [snapback]256823[/snapback]
    cjavier
    Okai here's my stock 5th gen from the VIC Dyno day at Dr Drift's!
    - Carl
    Junior Member radiotak's Avatar
    Dec 2006
    83
    Mods - AEM V2 Intake, Megan headers & High flow cat, cat back 2.5" Lukey system by Ian Diffens, NGK iridium plugs, Apexi Neo AFC
    (Bear in mind this is an auto and we ran it on a pretty warm day)
    Red is pre-tuning the Vtec engagement on the AFC, blue obviously after. The AF adjustment on the Neo isn't working at the moment, so I've got to get that sorted and get it back for a proper tune (apparantly this happens a lot more than it should with Neo's). 144.5hp (around 108kw) at the wheels though not too bad so far.
    Troy
    ___________________________________________
    So long and thanks for all the fish!
    Regular Member koj's Avatar
    vti-r
    241
    bee bee bee bee six?
    migoreng
    <edited comment on your dyno only>
    my car gets 106.5kw stock
    here's an old graph...completely stock but services were not completed back then. i was surprised my car managed to do that...
    Regular Member DMT's Avatar
    413
    Only mechanical mods are Simota Intake and Magnaflow rear muffler
    Regular Member Kronn 98SH's Avatar
    Type SH
    United States
    204
    I converted everything to metric just for you Aussies.
    Temperature: 19.4ºC
    Humidity: 7%
    Car: Mine
    Baseline: generic CAI w/ K&N filter, 2.5" custom crush-bent exhaust
    Header: HyTech replica
    Tuning: VAFC-II
    1988 Prelude S - victim of an 80mph backflip
    1991 Prelude Si - sold
    1989 Accord DX - impounded
    1998 Prelude SH - bolt-ons dynoing @ 173whp&140tq
    2006 CRF150F - acquired 6/20/09
    Small 5th Gen Part-Out, SH & Base, OEM & Aftermarket
    110
    Quote Originally Posted by koj View Post
    where is your sheet kenny?
    my car is quite freakish now.. its fun
    Good to see that you're enjoying your power. Unfortunately my car was turd to drive even with those mods until i installed a mfactory 4.64 FD.
    anyways:
    Skunk2 Stage2 Tuner cams
    Skunk2 Tuner cam gears (timing = dont have a clue)
    Skunk2 valve train
    Custom headers (not too sure who made it) with 2.5" mendrel bent exhaust from the collector.
    CAI
    Hondata s100
    Lightened flywheel (can't remember brand)
    mfactory 4.64 fd (No power increase as i made 119kw with the stock fd)
    I think thats it....
    Senior Member PrelUDeman's Avatar
    Apr 2008
    626
    Car: 99 prelude VTIR
    Power:120KW
    Engine:H22A
    Modifications: Headers,Exhaust, SRI, Lightened flywheel
    Transmission:manual
    Wheelsheavy GAH!!) 17" 215
    Fuel:98
    increased the torque by over 30NM as you can see in graphs. It is much more driveable and the torque is definately felt through out the rev band as you can see below. It pulls alot harder and i can actually keep the car in 3rd or 4th around a round about and not worry that i have no torque what so ever. ITS GREAT!!!!!
    VTEC just Kicked In Yo!!!mmmMMMMMMMMMMBBBAAAAHHHHH!!!!!!
    WTB- Rear strut, Front/Rear Sways, JDM Visors.
    GIMME GIMME GIMME!!
    Regular Member rbk_212's Avatar
    VTi-R ATTS
    Jan 2009
    463
    Car:1997 Prelude VTi-R ATTS
    Power:115.3kw
    Engine:H22A4
    Engine Mods:extractors, metal cat, 2.25" cat back, modified airbox, E-Manage Blue w/ injector and ignition harnesses
    Transmission Type:Manual
    Transmission Mods:nil
    Other Relevant mods:nil
    Wheels/Tyres:205/50/16
    Fuel:98 RON (BP Ultimate)
    May 2010
    14
    Attachment 4784
    Car: 1997 Vtir ATTS
    Mods: 2 1\4 inch custom made catback, highflow cat, hurricane extractors, trust intake, Apexi neo
    migoreng
    97 VTIR, H22A4 with 230,000km
    K&N Panel filter with intake resonator removed
    Stock header
    Hi flow cat
    Tanabe Medalion Touring Catback. 2.5" I think?
    NGK spark leads
    Iridium IX spark plugs
    New o2 sensor
    Castrol Edge 5w30 (Did see a little white/grey smoke during high cam so I am burning a little oil)
    Exedy Heavy duty clutch with stock flywheel
    215/40/17x7 tyres/rims
    Apexi AFC Neo
    Mar 2010
    106
    Mods:
    Cold air
    Full exhaust (2.25,100cell hiflow cat)
    Emanage Ultimate
    JAK motorworks
    KMS : 187xxx
    spare 5th gen Dash, door trims, Front and rear seats, carpet, centre console, and sun visors. pm for more details.
    migoreng
    Went to a dyno day today.. happy with the results
    Not bad for 250,000km and basic intake/exhaust mods + tune... still got the same as a corolla sportivo..not sure what mods it had...
    Jul 2007
    4
    Hi guys, just recently joined the prelude family.
    Here is my graph - H22Z motor, manual at 130,000 km
    Only (engine) modifications are a VAFC 2 tuned by TODA racing
    Uploaded with ImageShack.us
    Certainly made a big difference to how the car drives in the mid range, much improved.
  1. 4th gen pwr folding mirrors to 5th gen usdm mirrors
    By TrueBlueLude in forum General Prelude Discussion
    Last Post: 24th March 2005, 03:44 PM
  2. 1997-2001 (5th Gen) H1 Bulb Comparison And General Information
    By gerhard in forum General Prelude Discussion
    Last Post: 9th February 2005, 01:09 AM
